Speedsk8
Dec 28, 2019Tutor
MR1100 – Nighthawk LTE Mobile Double Nat on Xbox
Trying to grt rid of Double NAT on son's Xbox Have a Nighthawk LTE AT&T Modem thta directly feeds a unmanged switch. I have set the XBox to a static IP outside my DHCP pool, Set up the port forwardin...
- Dec 28, 2019
> MR1100 [...]
Firmware version?
> [...] the router/modem [...]
That's the MR1100, not some additional device?
What's the WAN/Internet IP address of the MR1100? Is it a public or
private address?If your ISP uses carrier-grade NAT, then that would put an additional
NAT router between the Internet and your router.https://en.wikipedia.org/wiki/Carrier-grade_NAT
Note that there's a forum for these devices:
michaelkenward
Dec 29, 2019Guru - Experienced User
If you need more help, you might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Mobile Routers, Hotspots & Modems
