ruimanalmeida
May 08, 2018Follower
MR1100 – Nighthawk M1 Mobile Router - could it replaced a home router ?
Hi, I was wondering if I could replace my old router by M1 mobile router? Does it have range enough to be used at all rooms inside a medium house? Or it's range is limited and I should buy a home rou...
winger13
May 20, 2018Guide
The device's wifi signal does not work reliably in a medium to larger home.
