AndrzejTaczala
Jun 19, 2020Aspirant
MR1100 – Nighthawk M1 Mobile Router
I have two issues with my MR1100 – Nighthawk M1 Mobile Router 1. the crescent light signaling the strength of wifi is not working 2. cannot log in to the application after its reinstallation t...
Blanca_O
Jun 28, 2020NETGEAR Employee Retired
May we please know the device SKU (MR1100-xxxx)?
Kindly do a factory reset using the Reset button. Press and hold the Reset button for five seconds. The mobile router returns to factory settings.
Blanca
Community Team
AndrzejTaczala
Jul 04, 2020Aspirant
Hello Blanca,
Thank you for reply and sorry for may respond being late. I reset the unit but it didn't help for both issues. Simply because after resetting, the unit does not go to its factory setting in terms of 'admin' login, instead it goes to my last setting i.e. it required the password that I set, not the one printed on the unit sticker. So, virtually I could not communicate with my unit neither by using app nor by web site. The option for "you forgot your password?" is useless now because Netgear people do not now serve us at all. The 'Help' number for Dubai where I stay is usless too. Auto message says the number is wrong.
After so many attempts with various possible options for my password I finally succeeded and got the right one.
So now I have a full communication with my unit, but unfortuntely I could not find any way to fix the issue of the light to show the strenght of wifi (the right crescent light).
As a result of these Netgear issues I have decided to opt for new router with permanent fibre optic connection.
So my Negear unit became useless and faulty though still with 1 year warrnty from Amazon.ae. where I bought it.
Best regards,
Andrzej
- AndrzejTaczalaJul 04, 2020Aspirant
Hi Blanca again. You asked for full number: MR1100-100.
