markuspookus
Jul 09, 2019Aspirant
mr1100 - disable sip alg
Hi Trying to use these devices as a failover for a cabled internet connection for multiple clients. Got the failover working, however I need to find out if SIP ALG is enabled by default and if so,...
- Jul 11, 2019
Hi Mark,
SIP ALG is enabled by default on the MR1100. There is no way of easily disabling via the webUI. The latest Nighthawk M2 MR2100 however does give user the option to disable SIP ALG via the webUI.
Arodi
Community Team
ArodiD
Jul 11, 2019NETGEAR Expert
Hi Mark,
Arodi
Community Team
markuspookus
Jul 11, 2019Aspirant
Thanks for that.
So I ask the obvious question.
Is there a Hard way to disable it, not using the WebGui ?
Regards
Mark
