brygida
Aug 05, 2020Follower
MR1100 - Nighthawk M1 Gigabit LTE
On my router, after correctly inserting the sim card, the message no sim card is displayed or the sim card is inserted incorrectly. The sim card works fine on other devices. What should I do?
Blanca_O
Aug 12, 2020NETGEAR Employee Retired
Hi brygida
Welcome to NETGEAR Community!
Kindly ensure that the micro SIM card is installed correctly. Please check this reference: http://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf [page 11 - 12]
Do you have other SIM card you can try on the MR1100 to isolate the issue?
Was this working before?
Blanca
Community Team
