Peanutguy
Dec 29, 2020Aspirant
MR1100 - No option to upgrade firmware
Hi All, I have a unlocked ATT M1 that's on Cricket and doesn't get any OTC firmware updates, nor do I have a place on the firmware update page to manually upload a spk. Does anyonen know how I can u...
Blanca_O
Jan 04, 2021NETGEAR Employee Retired
Hi Peanutguy,
Welcome to NETGEAR Community!
May we please know the device SKU (e.g. MR1100-100NAS)? This can be checked on the box of the product or on the barcode label
MR1100-1A1NAS and MR1100-2A1NAS SKUs are AT&T devices. There is no option to manually update the firmware as it is locked by the Internet Provider.
Blanca
Community Team
- PeanutguyJan 04, 2021Aspirant
Hi Blanca,
The model is a MR1100-1A1NAS. Since the device is unlocked, there should be some way to update it via a telnet command or another way.
- SFermindiJan 06, 2021Tutor
Hey Peanutguy - I went thru same deal with Gen 1 MR1100-1A1NAS. I have AT&T service but no option to upgrade the firmware. Even tried AT&T tech support to push to firmware to the unit but no luck. So, I solved the problem by flashing the firmware from AT&T 12.05.05.00 (Sept 2018) to the latest Netgear version 12.06.11.00 (Jan 2020). This was made possible by method from Mrblazed. I was a little reluctant to try, but it worked and I now have better speed too. Wasn't sure that AT&T would recognize the SIM after the flash, but no issues at all. Here's the process I followed:
@Mrblazed wrote:
Download the newest generic firmware from the Netgear support site for your country (the routers country).
https://www.netgear.com/support/product/MR1100.aspx#Firmware%20Version%2012.06.11.00Download FDT.exe version 4.6.2.0. (You’ll have to Google)
https://www.dropbox.com/s/s27ftyfjpvn9819/fdt.exe?dl=0Download AC78x Netgear drivers version 4.3.00
http://www.downloads.netgear.com/files/aircard/AC_790S_Telstra/AC78xSDrivers.exe
Download Putty
https://www.putty.org1) Put everything in the same folder (ex. C:\Desktop\mr1100 )
2) Install drivers
3) Connect MR1100 directly to computer with USB cable.
There are 2 USB ports on the MR1100. Standard and Micro (micro is same port used for charging the MR1100).
Use of the micro USB port for connecting the MR1100 to your PC.
4) Open putty, telnet into MR1100 ip address (default is 192.168.1.1 which is no secret) with port 5510
Note: normal telnet session prompts for login ID and password. You don't get that here, so just start typing thefollowing command.
5) AT!BOOTHOLD
Once you type this command, you will get a response back just saying 'OK'. You should also see 'NetGear' boldlydisplayed on the MR1100,
and the small status LED will be flashing red.
6) Close Putty
7) Open 'cmd' window, change directory prompt to where you downloaded everything to (exC:/Desktop/mr1100). Type ”fdt.exe insertfilename.secc.spk” and hit enter.
fdt.exe NTG9x50C_12.06.11.00.secc.spk
8) Do not touch anything. If the command prompt tells you after “resetting device” that the upgrade failed, ignore itand let the MR1100 do its thing. The screen on the MR1100 may show its downloading the firmware, and at
some point It may look like it’s frozen, but it should finish and boot by itself after about 10 minutes. Again as
Mrblazed advised, DON'T MESS WITH IT UNTIL COMPLETELY DONE.
9) When its done, the display on the MR1100 should look different, and have status info, usage amount...etc on
the display.
make sure you can page through the different displays on the screen using the 'home' button on the MR1100.
You can also log into the MR1100, and navigate to Settings > Administration > Firmware Update... there you
should see the new firmware version, which also confirms your MR1100 update was successful.
So after all said and done, I was still having issue with battery charging. The MR1100 would get to about 33% charge and then discontinue with overheat mode. I solved that issue very easily by shutting modem off for a couple of hours. I then tired a different trick by adding a cooling fan from AC Infinity that fits nicely between my router and the MR1100. It now registers a much cooler temp and will charge while the unit is being used. Only $13 on Amazon. Voila!!!
Pics that didn't work.
