Ni_co_las
May 21, 2018Aspirant
MR1100 - poor internet quality
Hi,
I purchased the MR1100 (US version).
I did some testing in order to check that it is a good investment. What a disappointment!
I made lots of internet speed testing with the MR1100 and also...
jpr78
May 22, 2018Tutor
Were you using the MR100 WIFI for testing? If so, the 2.4Ghz WIFI band on the MR100 is not good. If you did all your testing on this connection, either try the 5 Ghz WIFI band or try Ethernet instead. You will most likely see much better speeds.
tmoffitt
Aug 19, 2018Aspirant
Having the same issue. Decent ATT cell service on my Iphone X with 25 mbps or more down. Can't get anymore than about 2-3 mbps on the Nighthawk. That's both 2.4ghz or 5ghz. Any suggestions.
- jpr78Aug 19, 2018Tutor
Does ethernet give you good speeds? If so, get a wireless router and disable wifi on the nighthawk.
- tmoffittAug 19, 2018Aspirant
Unfortunately, no. Tried that. Same speeds.
- JSchnee21Aug 22, 2018Virtuoso
I also have the AT&T MR1100. On 5.8Ghz, 40Mhz, I typically get up to 90Mbit down (25-40Mbit is more common) and 5-15Mbit up. When comparing side by side to my iPhone 6s during my ~90min commute, my iPhone beats it every time. Not by much, just 5-15Mbit, but seriously? My iPhone is like 3 years old ?!?!
My AT&T Velocity 2 gives roughly the same performance as the MR1100. Slighly slower (5-10Mbit) at times. It was half the price and has better stability, better Wifi range, and a tough screen.
-Jonathan
