Ultratc's avatar
Ultratc
Follower
Sep 16, 2019
MR1100 - Question about signal bars
I am trying to figure out if more signal bars on the router equates to faster speed. Can anyone help?
thanks
  • Hi Ultratc
    Welcome to NETGEAR Community!
    The signal bars is the router's signal indicator. For example, if the signal indicator always low then it means that your mobile router’s reception is poor. Try moving it to a location with a clear view of the sky (for example,
    near a window).
    Blanca
    Community Team
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Ultratc
    near a window).
    Blanca
    Community Team
