Watson306
Jul 22, 2022Aspirant
MR1100 - Unable to update firmware
Hi Guys, I have a MR1100 MiFi and if i use the automated search for firmware it says I have the up to date firmware. But if I search on the webite it says there is a more up to date version. But i...
schumaku
Jul 22, 2022Guru - Experienced User
There exist at least half a dozen different MR1100 models. Firmware is not exchangeable, band plan and modulation versions is preconfigured and depends on the carrier and/or market requirements.
Watson306
Thanks for your reply.
Do you know where I can find out the version I have?
