Watson306
Jul 22, 2022Aspirant
MR1100 - Unable to update firmware
Hi Guys, I have a MR1100 MiFi and if i use the automated search for firmware it says I have the up to date firmware. But if I search on the webite it says there is a more up to date version. But i...
schumaku
Jul 22, 2022Guru - Experienced User
There exist at least half a dozen different MR1100 models. Firmware is not exchangeable, band plan and modulation versions is preconfigured and depends on the carrier and/or market requirements.
richallcorn
Sep 20, 2022Aspirant
After reading some of the posts here, I would NOT recommend updating the firmware. One guy posts that his unit suddenly became a battery hog and battery life went down considerably. Whats that old saying, "If it ain't broke, don't try to fix it." LOL
Good luck ...
-rich-
Rich Allcorn
http://rich.allcorn.us
