Nico_50660's avatar
Nico_50660
Follower
Jul 30, 2022
MR1100- need to unplug the power supply ?
I just set up à brand new MR1100 4g router.
When the battery is charged, is it recommended to unplug the 220V power supply, until the embedded battery is uncharged ? Or is it better to remove the battery and always keep the 220V power supply plugged, when using the MR1100 at home ?
Thanks for your advice,
Nicolas
1 Reply
  • michaelkenward's avatar
    michaelkenward
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Mobile Routers, Hotspots & Modems
    Those things are very different from the standard Netgear routers covered in this section.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
