greger55
Jun 23, 2023Aspirant
MR1100-100 cant connect to any device to start up
Hi I am helping my father with his Netgear MR1100 router, we cant connect the router to any device, the wifi that the router shows dosent appear on any device either mobile or computer. The mobile ap...
schumaku
Jun 23, 2023Guru - Experienced User
It's the other way round: One does connect (or associate) wireless clients to the MR1100 access point.
greger55 wrote:
The mobile app isnt availible for download on any of our mbiles beacause we have a newer version of android.
Netgear Mobile app (as refered on https://www.netgear.com/support/product/mr1100#download) can be installed flawlessly on a current Android 13 (Build TQ3A. ....) Pixel 6a scratch installed and updated as we are writing here. Very unlikely there are much newer Android versions out here.
What mobile phone make, model are we facing here?
greger55 wrote:
I have tried to connect the router with a ethernet cable to acces the m1login page but that dosent work either..
The Ethernet link from the computer is coming up?
Is the adapter configured for DHCP?
Is an IP address assigned to the computer?
Tried http://192.168.1.1/ instead?
greger55
Jun 24, 2023Aspirant
My father has a Xiaomi and he has been able to download the app, but even with different sim cards in the device, so we cant get in to it with either the phone or computer with ethernet.
- schumakuJun 24, 2023Guru - Experienced User
With the WiFi SSID not becoming visible, I suspect something essential is wrong with the device status. Needless to ask if you have done a factory reset one might guess. Carrier SIM is irrelevant, because all it requires is a WiFi connection. Don't hesitate to get in touch with the Netgear Customer Service via https://my.netgear.com/ please.
