MolloyC's avatar
MolloyC
MR1100-100 connecting to internet with new SIM
My MR1100-100 mobile hub will not connect to the internet after switching SIM providers from EE to '3' in the UK. Is it because '3' is not compatible ?
  • You would need to make sure this MR1100-1EEEUS is unlocked from EE before moved to SIM card from the other carrier
    • MolloyC's avatar
      MolloyC
      Yes I have checked that it is unlocked by EE but I don't know if it is unlocked by Netgear. It just says "Mobile broadband disconnected...your data connection is disconnected "
  • Was this device bought directly from a mobile service provider such as EE? If so, it's likely it will be locked to the mobile service provider it was bought from.
    If the Three SIM works in a different device which is unlocked, it's quite likely the device that doesn't work is locked to a different network.
