UweK
Sep 27, 2018Tutor
MR1100-100 LTE router : can I configure it to act only as WiFI repeater ?
Hello, have the Nighthawk MR1100-100 in my mobilehome / motorcaravan and works technically fine.
here my issue and question :
to save LTE datavolume I am using Dataoffloading as much as I...
- Oct 05, 2018
Hi Christian, found the setting ‚Daten im Heimnetzwerk‘, sounded to me as something around local wifi at home, hence I never played with that.
Toggling this disables Mobile Data - exactly what I wanted !!
connecting to a wifi with mobile data disabled works, but the network diagramm of the App shows LTE not connected (correct) and Wifi not connected as well ( not correct ).
The display on the router itself shows lTE not connected, but Wifi connectd ( which is correct )
its a bit misleading, but seems to work. A bit disappointing that Network support has no idea and clearly told me on the phone ‘not possible’
many thx for your help
Christian_R
Oct 04, 2018NETGEAR Employee Retired
UweK
Oct 05, 2018Tutor
