Yada
Apr 25, 2025Follower
MR1100-100 M1 Do not boot anymore
Hi all, My M1 is no longer under warranty and does not boot anymore (with or without battery, with or without SIM). It seems to be a hardware issue. If I press firmly on the screen with constant ...
- Apr 28, 2025
#4 would be the only valid option. Get an M6 or M7 generation if you can afford it. Maybe get one used off of eBay or Amazon. Just make sure you do your homework to make sure the model you buy has bands for your carrier.
rcpax
Apr 28, 2025Luminary
