Al00000
Jun 14, 2020Tutor
MR1100-100 Nighthawk Rebooting Fiasco
I'm in the UK and I bought my MR1100 from Amazon in October 2019. Since then, I've suffered from the well-reported rebooting issue; which seems to be power/firmware related. I've sufferered f...
JohnPeng
Jun 14, 2020NETGEAR Expert
Please provide the FW and PRI version on your device. And let me know the carrier you are using.
We will follow up to find the root cause of the resets and resolve it asap.
Sorry for the inconvience.
Thanks
- Al00000Jun 14, 2020Tutor
Hello,
My Firmware is NTG9X50C_12.06.12.00
I'm on the 3 UK Network
I do not know how to find PRI
Thanks
- Al00000Jun 19, 2020Tutor
JohnPeng wrote:Please provide the FW and PRI version on your device. And let me know the carrier you are using.
Hi John,
Are you able to help with this? I've provided the information that I have.
Thanks,
Al
- Al00000Jun 24, 2020Tutor
Hi John,
Thanks,
Al
I guess not
