Al00000
Jun 14, 2020Tutor
MR1100-100 Nighthawk Rebooting Fiasco
I'm in the UK and I bought my MR1100 from Amazon in October 2019. Since then, I've suffered from the well-reported rebooting issue; which seems to be power/firmware related. I've sufferered f...
Blanca_O
Jul 06, 2020NETGEAR Employee Retired
Hi Al00000
Kindly access MR1100 settings page, go to Settings > Device to get the PRI version.
Here's a reference of How do I log in to my AirCard Mobile Hotspot?
Blanca
Community Team
FilB
Sep 08, 2020Aspirant
I'm also in the UK and using a SIM from Vodaphone which has worked for two years so far.
Yesterday my nighthawk just started disconnecting itself every 30+ seconds making it unusable not only for my network but also for my alarm system which connects through it.
I'm unable to try any of the "fixes" I've seen so far as the router doesn't stay connected long enough to get in and amend a setting.
Even trying to get a replacement SIM requires a flight back to the UK , surely theres an easier way to fix this?
