swissy89's avatar
swissy89
Follower
Apr 27, 2023
MR1100-100 WiFi PSK bug
FW: NTG9X50C_12.06.39.00
If the PSK for the WiFi ends with a '+' sign, it will save it as ending with a ' ' (space).
I did multiple factory resets and tests with different passwords, and always got the same result.
Tested using the android Netgear app. Not sure where the problem exatly is.
This is more than awkward. Please fix.
No RepliesBe the first to reply
