abhi093's avatar
abhi093
MR1100-100EUS : Intra band 2CA 40A+40A and 1A+3A +40A+40A support
Does the MR1100-100EUS supports the below combinations? or can you add  them included in the firmware update . these combinations are supported by indian telecom operators. It's very much needed here.
JohnPeng
Intra band 2 and 4 carrier aggregations : as below
2CA  --- 40A+40A and
4CA -- 1A+3A+40A+40A
  • 2CA  --- 40A+40A              ---> 40C2 is supported
    4CA  -- 1A+3A+40A+40A   ---> not supported
