anttij's avatar
anttij
Follower
Jun 05, 2018
MR1100-100EUS ipv6 support
There is mixed information about ipv6 support of Netgear M1 specifically MR1100-100EUS.
This is the operatorfree EU version.
So does it (MR1100-100EUS) support ipv6 or not?
  • Blanca_O's avatar
    Blanca_O
    Jun 17, 2018
    Hi anttij and networksman,
    Welcome to NETGEAR Community!
    The device does not support IPv6.
    Additionally, MR1100 support IPv6 on LTE/WWAN side and this has to be configured when configuring APN. It is on the LAN side that IPv6 is not supported as there is no option to configure it.
    Blanca
    Community Team
  • Yes I am curious about this too, I want to buy the one on Amazon to use traveling in the US and was wondering if its the same as the US version for band support?
    • Blanca_O's avatar
      Blanca_O
      NETGEAR Employee Retired
      Blanca
      Community Team
