antbg
Apr 02, 2022Aspirant
MR1100-100EUS problem with roaming
Hello everyone, I bought a SIM here in Greece which can connect with all operators (not at the same time). Here in Greece there are 3 operators basically Cosmote,Vodafone and Wind. The problem is...
JohnPeng
Apr 03, 2022NETGEAR Expert
Under the APN setting up, you can find a checkbox for Roaming data. You need to check the box in order to enable roaming.
Please give it a try.
antbg
Apr 03, 2022Aspirant
Hi John,
Thank you for your reply.
You mean above the apn settings. I have already done that:
The image was taken from google search as I am not home right now. But this is exactly what I see. Except the fact that my apn settings are different and it doesn't have the ATT logo on top.
