antbg
Apr 02, 2022Aspirant
MR1100-100EUS problem with roaming
Hello everyone, I bought a SIM here in Greece which can connect with all operators (not at the same time). Here in Greece there are 3 operators basically Cosmote,Vodafone and Wind. The problem is...
antbg
Apr 03, 2022Aspirant
Hi John,
Thank you for your reply.
You mean above the apn settings. I have already done that:
The image was taken from google search as I am not home right now. But this is exactly what I see. Except the fact that my apn settings are different and it doesn't have the ATT logo on top.
JohnPeng
Apr 03, 2022NETGEAR Expert
Yes. That is the one. By default, roaming data is disabled to prevent user from getting unexpected high roaming charges.
