antbg
Apr 02, 2022Aspirant
MR1100-100EUS problem with roaming
Hello everyone, I bought a SIM here in Greece which can connect with all operators (not at the same time). Here in Greece there are 3 operators basically Cosmote,Vodafone and Wind. The problem is...
Damianos
Jul 30, 2022Initiate
Antbg,
Did you find the solution?
I’m experiencing exactly the same problem as you.
I’m on vacation in Greece and when I put my origin telecom operator SIM into M1 (roaming data enabled on M1 as well as on SIM itself) the internet connection doesn’t work while it worked when I’ve tested it in my country.
It seems that M1 has some problems with roaming.
Damian
Damian
- antbgAug 01, 2022AspirantNo unfortunately I have not found a solution. Indeed it seems that it has some problems with roaming. It is such a pity considering how expensive the device is.
- DamianosAug 03, 2022Initiate
To be honest, it is f*cking ridiculous that I pay so much for the device with so simple functionality and it doesn't work as expected.
Very basic models of mobile phones which are much less expensive than M1 are able to roam data.
