TM3522
Dec 20, 2019Tutor
MR1100-100EUS stop updates.
Hi, like the subject.. I want a way to stop auto updates. thanx
- Jan 15, 2020
Hi TM3522
Welcome to NETGEAR Community!
There is no option to disable firmware updates on MR1100. You will be notified that there is an update available and will be given an opportunity to update the firmware 3 times. If after the 3rd time the firmware is not updated then MR1100 will update the firmware.
Blanca
Community Team
Blanca_O
Jan 15, 2020NETGEAR Employee Retired
Hi TM3522
Blanca
Community Team
