crawfordj
Apr 30, 2019Follower
MR1100-100NAS Boot Loop and Powers Off
Brand new MR1100-100NAS. Went to Verizon worked with associate to get a plan and micro sim purchased. Went well. She installed sim and booted up router. Everything worked. Successfully connected mobil...
mobileguy
May 01, 2019Aspirant
I just had this same experience on my MR1100-100NAS model that I have used almost every day since early Sept 2018 on AT&T network. the device will never boot sucessfully, just does the reboot loop as you describe. Went through troubleshooting steps over the phone yesterday, Netgear tells me they will replace device under the 1 year warranty, however they have none of this model in stock right now. Not sure what is going to happen.
mobileguy
May 02, 2019Aspirant
Updating with additional information. I have not heard back from anyone at Netgear yet. My router was also the 100NAS model. I also tried with power only, power w/ battery installed, battery-only, etc. I was never able to get the device to perform a "factory reset" because of the state it is in. I have factory reset my failed model and another identical model in past so I am familiar with that process, but once the router gets in this state, have not found a way to get it out the reboot loop of death.
- Orion007May 03, 2019AspirantWonder if this is related to the new firmware that was released yesterday?
- mobileguyMay 03, 2019Aspirant
Can you be more specific about the firmware release you are referring to? I see notices about new firmwares in this forum but most of them are not for United States or AT&T which is the main carrier supporting most users of the Nighthawk MR1100 in the US.
I will also add I have another 100NAS model that is still working and I also use on AT&T on a daily basis. It has at this point been weeks since my other 100NAS died. And in those weeks, the other identical model has not given any indication of downloading or applying a firmware update. And this unlocked version does have the "check for updates" button which I have triggered manually as well. I get the message "No Update available... Current firmware is up to date". I do not get an error as many have reported lately. So I don't think in my case this is because of a new firmware, but I don't have enough information to prove it.
