FCB90
Apr 16, 2019Star
MR1100-100NAS no B20, NO SCC Carrier aggregation
Hello, I am using the MR1100-100NAS device. Firmware: MR1100-100NAS_23113828_NTG9x50C_12.05.05.00_00_GenericNA_01.02 (newest).
The device does not support the B20 frequency, the aggregation is a...
FCB90
Apr 16, 2019Star
Also adding second screenshot showing aggregation that just doesn't work.
- TeeJay74Apr 16, 2019Virtuoso
What are the other bands/cells what you miss ?
- FCB90Apr 17, 2019StarThank You for your answers.
B1+B3+B7 should be aggregated and it's fully supported by BTS (checked with few other devices with the same SIM) - again, it's not problem with SIM, BTS or ISP.
None of aggregation is working, 2CA too.
NETGEAR'S Support, could You please tell me if aggregation on my device can be somehow blocked?
MR1100-100NAS should support also B20, it's officially confirmed by NETGEAR - I've checked and it's not so it seems to be an critical bug in modem's firmware.
Without aggregation the device is almost useless in normal conditions.- W1lliamApr 17, 2019Virtuoso
From the screen capture you provided, current firmware does not support B20, it might be limited by the firmware, need to wait for Netgear's official explanation if that was done in purpose or can be added in later firmware.
William
- W1lliamApr 16, 2019Virtuoso
it seems this unit does not support B20, from the first screen capture, you might need to check on specsheet from the vendor for 100NAS. As for aggregation, it would be depending on the carrier if they do support aggregation.
William
