FCB90
Apr 16, 2019Star
MR1100-100NAS no B20, NO SCC Carrier aggregation
Hello, I am using the MR1100-100NAS device. Firmware: MR1100-100NAS_23113828_NTG9x50C_12.05.05.00_00_GenericNA_01.02 (newest).
The device does not support the B20 frequency, the aggregation is a...
FCB90
Apr 16, 2019Star
Also adding second screenshot showing aggregation that just doesn't work.
W1lliam
Apr 16, 2019Virtuoso
it seems this unit does not support B20, from the first screen capture, you might need to check on specsheet from the vendor for 100NAS. As for aggregation, it would be depending on the carrier if they do support aggregation.
William
