saktmototu
Jul 12, 2021Follower
MR1100 1TLAUS (Telstra) Rebooting Loop after update firmware
Until a few days ago, my m1 was running well, but suddenly it would not broadcast wifi Even if I have turned on wifi or reset the machine back to factory settings, it is the same Therefore, I used ...
Blanca_O
Jul 23, 2021NETGEAR Employee Retired
Hi saktmototu
Welcome to NETGEAR Community!
Firmware upgrades are provided over-the-air. Manual upgrade is not suggested since the file may be for different hardware and may damage your device.
Since you have an ISP (Telstra) unit, we suggest to contact them to do a hardware check. Here's a reference link: https://kb.netgear.com/23955/How-to-get-an-AirCard-product-warranty-Return-Materials-Authorization-RMA-repair-purchased-obtained-from-an-Internet-Service-Provider
Blanca
Community Team
