SDPearson's avatar
SDPearson
Follower
Feb 03, 2019
MR1100 and Google WiFi
Any issues connecting the Google WiFi mesh system to the MR1100 using the Ethernet plug?
1 Reply
  • Just the usual:
    1) turn off wifi on the MR1100
    2) make sure your Wireless AP's are set to DHCP or in a Static range that won't conflict
    3) DHCP in the MR1100 only supports 20 devices.  If you have more, you will need to use statics and/or a separate DHCP server, or double NAT with a home router.
    4) Get a small ethernet switch (e.g. Netgear GS105 or GS108) to connect your AP's to.
