Gulph
Jun 11, 2019Aspirant
MR1100 and Mobile App Problems
I've installed the mobile app on Iphone and setup to manage my MR1100 then it prompted me to Install Nighthawk and ever since I am unable to login again. The error is wrong password.
JoseAndres041
Jun 12, 2019Luminary
Hey. So you installed the Mobile app, successfully installed your MR1100 and then it asked you to install the Nighthawk app? Could you login to the router using a web browser?
- GulphJun 12, 2019Aspirant
Thanks for the contact. I did a reset of the device, now all's good.
