DamianR's avatar
DamianR
Tutor
Apr 02, 2020
MR1100 AUS Firmware problem/update
Current Telstra FW 12.06.08.00 has serious problems with battery charge.
Current Intl FW is 12.06.11.00
FAQ says:
  • Updated AutoAPN database to 01.30
  • Reverted a change that could potentially cause the device loses data connection when temperary out of coverage
  • Addressed the issue that Heated Battery Alert is displayed prematurely
  • Addressed the connection issue when ethernet offloading to Orbi
  • Disabled WiFi and Ethernet port standby timers when the device is tethered or charged
When will these changes appear for the AUS Telstra version ?
Or, should I give up waiting & try the forced update procedure to the generic one ?
  • Hi,
    Same problem here, currently on Telstra FW ver. 12.06.08.00,
    my router keeps disconnecting due to  short network losses
    (poor coverage in my area... anyway, not the problem here)
    Problem is it won't reconnect until I switch data off and on in the app... pretty annoying !
    Last FW  ver. 12.06.11.00 seems to solve also this problem ,nice!
    But why do we, Telstra users have to wait months until new firmwares comes out?!
    I'm also keen on testing FDT.exe method to force firmware install,
    but I read about bootloops and other bugs and wouldn't like to brick the thing...
    • benyba's avatar
      benyba
      Guide
      rmx I did it yesterday on my AUS Telstra MR1100 and flashed the latest 100NAS FW. It works with no issue at all and even keeps previous settings and specific bands combination I had in place. Just don't try to flash the EUS FW. I confirm no loss of connectivity anymore :)
      • Rio_Moon's avatar
        Rio_Moon
        I can't update my M1 AUS version with NAS file
        Can u show me how?
