Ratfink5Window
May 17, 2020Aspirant
MR1100 battery bypass solutions??
AT&T suggested I buy this device to work remotely from home in a very rural area. Works great for Teams meetings and Zoom meetings. However, I want to leave this on and stop dealing with the battery g...
djt2020
May 20, 2020Guide
I have two MR1100s and both operate without batteries. This is the common solution to the overheating issue. Have to tried a higher power quick charge power adapter? That is also reccomended when taking the battery out. Perhaps yours is too weak to run it without the battery.
- Ratfink5WindowMay 23, 2020AspirantWith battery removed and using factory wall charger there is no way the MR1100 will run without a battery. I do have several quick chargers for various electronic devices. One will power the MR1100 without the batter but the charge level LED is low, and speed is too slow for downloads of even basic website data. So, does anyone know the specs of a quick charger that will easily and permanently power the MR1100 Nighthawk M1 without a battery? Can anyone point me to a high quality quick charger?
- djt2020May 23, 2020Guide
