Javan
Jan 29, 2020Follower
MR1100 battery disconnecting issue
So I just got a used Nighthawk M1 and when the battery is in and the device is on, any small bump or impact will cause it to instantly turn off. The only way to turn it back on after this is to take t...
JohnPeng
Jan 29, 2020NETGEAR Expert
The possible reason for this is that the battery contact PINs deformed. To correct this, you can pull the PINs up carefully or you can insert something to make the battery fit in the compartmemt tightly.
Thanks
