idck_de
Mar 02, 2021Tutor
MR1100 black out after a Code 3
Hi My MR1100 keep turn on and off itself. It brings up an message after I press the power button. And After a power on waiting on support line it drop black out the screen. I can touch the batter...
Gatorgurl
May 04, 2021Aspirant
I also have error Code 3 and am wondering why and how to fix it.
Thanks
idck_de wrote:Hi
My MR1100 keep turn on and off itself. It brings up an message after I press the power button. And After a power on waiting on support line it drop black out the screen. I can touch the battery the temperature is on high. So I shut it down and unplug both Type-c and the battery.
Anyone has ideas on how to fix it?
MR1100 Code 3
Model / Version: MR1100EUS
Firmware Version 12.06.12.00
idck_de
Sep 15, 2021Tutor
Update: I think my MR1100 is completely broken, Whatever I plug-in nor battery won't turn on, Connect to PC Mac looking for any words, Putty nor some driver non of them had any respond. Only slight orenge light that so diminished the hope is so light. Contact Netgear Phone Support they want me to purchased add-on services instead.
After months waitting and search. There's another post by someone with same issues. Blanca_O
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Code-3/m-p/2057101#M17630
