hmhaga
Sep 28, 2023Tutor
MR1100 boot loop
After enabling IP passthrough, the web interface would no longer save settings (apply button turned read). I then performed a factory reset, After the factory reset, the MR1100 is in an infinite b...
MyFriendSanta
Sep 29, 2023Star
ippassthrough requires mobile provider side changes to work.
if you cant get ip passthrough to work it's because you're dynamically being assigned a non-bridgeable external IP.
Only your mobile data service provider can make changes on their side to enable the use of your
enabled IP passthrough tickbox.
your best bet is to deny your providers DNS and to go straight to a VPN with all of your traffic requests at router level not modem.
- hmhagaSep 29, 2023Tutor
I know that IP passthrough might not work with cellular, but I wanted to try to eliminate the Deco M5 mesh as a simple access point, which disables most of its feature. What I expected to happen, was that the Deco M5 would query the cellular provider for its IP-address.
Anyhow, nothing works now with the MR1100 stuck in a boot loop. I can't reconfigure it.
