hmhaga
Sep 28, 2023Tutor
MR1100 boot loop
After enabling IP passthrough, the web interface would no longer save settings (apply button turned read). I then performed a factory reset, After the factory reset, the MR1100 is in an infinite b...
hmhaga
Oct 06, 2023Tutor
I'm still waiting for a solution on this one. Way too expensive hardware to simply go into a boot loop for no logical reason!
- FlintensteinOct 09, 2023AspirantSame here... entered boot loop last night in the middle of a movie. Hard reset does nothing. Unit is 2 years old- did Netgear push an update that bricked the device?
