hmhaga
Sep 28, 2023Tutor
MR1100 boot loop
After enabling IP passthrough, the web interface would no longer save settings (apply button turned read). I then performed a factory reset, After the factory reset, the MR1100 is in an infinite b...
hmhaga
Oct 23, 2023Tutor
The MR1100 was sent to a electronic repair facility, but they could not fix it. More electronic garbage due to bad quality.
The mobile network operator (Telia Norway), who I bought the MR1100 from initially, came to the rescue. They replaced it with a LBR20, free of charge.
