kasisbook's avatar
kasisbook
Follower
Mar 27, 2023
MR1100 Bootloop
Woke up around 3 am to my Nighthawk circling ... its done it like 3 times before i went to sleep but it would boot back up after I pop the battery out and reboot er. I've been searching all types of LTE hacking forums and read that i can flash an older firmware so Itried like 4 different firmware using the FDT method and nothing is working. It just boots up and shows the Netgear logo and circles .. then like 3 mins later itll shut off and do it again .. over and over again. Ive tried running off of multiple different charges and with out the battery ... Any suggestions before I throw this mf lol?...
  • plemans's avatar
    Did you try factory resetting? There's a hardware reset button below the battery pack
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Please advise the device SKU. Seems like the device is dead.
    Thanks
