joepgal
Dec 19, 2021Aspirant
MR1100 broadband disconnect
I had to do a factory reset on this device and now when it comes back up, will not connect keep getting broadband disconnected. This is on a Cricket network, not Tmobile. I have the latest firmware, ...
JohnPeng
Dec 22, 2021NETGEAR Expert
Did you try to set up the correct APN for your SIM card?
Thanks
- joepgalDec 22, 2021AspirantThat was the issue. It had an AT&T apn in there. Thought that since AT&T owns cricket, that was correct one. I added cricket and connected immediately. Thank you
- JLuckyDec 23, 2021AspirantI have installed an EE SIM card but it’s saying mobile broadband disconnected. I have done a reset.
Any ideas for someone with basic tech knowledge gratefully received.
