PHIL032
Feb 09, 2021Follower
MR1100 Cannot connect using rj45 ethernet connection
I have no problem using the wifi for multiple devices but if I connect a machine using the rj45 connector I get nothing. If I use the USB connection I get an IP address (still no internet) If...
Blanca_O
Mar 15, 2021NETGEAR Employee Retired
Hi PHIL032,
Welcome to NETGEAR Community!
Kindly access M1 Router UI and check the following settings:
Go to SETTINGS > Setup > Router Setup > USB port > select Charge Only > Apply
Go to SETTINGS > Setup > Router Setup > Ethernet Standby > set to Disabled > Apply
Here's a reference of how to access Router UI: https://kb.netgear.com/23379/
Blanca
Community Team
