aoxford
Jul 05, 2019Follower
MR1100 cannot login to http://m.home
Hi I am trying to to login to my nighthawk routher http://m.home to check all the messages but it will not accept the password that is on my modem. How do I overright this?
ArodiD
Jul 10, 2019NETGEAR Expert
Hi aoxford ,
As per schumaku 's comment the default password to log into the WebUI is admin and should be printed on the label on the back of the device(need to remove battery and cover to see label). If the device still does not accept the password then there is a chance that the password has been modified. If the password was modified and forgotten then the only way to regain access to WebUI is to perform a factory reset via the reset button(need to remove battery cover to see reset button).
Arodi
Community Team
