RedRaspberry
Feb 29, 2020Guide
mr1100 cannot obtain ip address
I have an unlocked ATT Nighthawk MR100 router. Originaly I could connect with it through a browser on either my laptop or phone and entered the unlock code. Then was able to change the APN to the...
- Mar 06, 2020
I had to do a factory reset and then enter the unlock code again. It all worked then when I put the new SIM in. It is a TMobile SIM.
JohnPeng
Mar 05, 2020NETGEAR Expert
"But when I put in a SIM for my cell company I then get the error message Device locked visit http://attwifimanager"
What SIM card you used here? The above info shows that your device is not unlocked from AT&T.
Thanks
- RedRaspberryMar 06, 2020Guide
