BgTX
Feb 13, 2021Guide
MR1100 cannot update firmware
Current router fw version: NTG9X50C_12.05.05.14 Latest fw version: 12.06.11.00_00 firmware check using web and app UI, specifies the device is up to date. There is not upload "button" available ...
- Feb 19, 2021Thanks for screenshot. It was very helpful to identify the issue. Your device is MR1100-1A1NAS which is an AT&T variant. The FW in the link you provided is for MR1100-100NAS which is the retail variant. The firmware for your model is upto date as AT&T have not released anything later. I hope this helps clear up the confusion.
BgTX
Feb 17, 2021Guide
Thank you Arodi. I attempted a reset. Sadly, no change.
ArodiD
Feb 17, 2021NETGEAR Expert
Hi BgTX ,
Can I confirm that your device is currently on NTG9X50C_12.05.05.14 and it shows there is an update available as a notification but there is no download or update button in the WebGUI to update? Can you please help to provide a screenshot of your issue?
Arodi
- BgTXFeb 17, 2021Guide
That is the correct fw version.
When I go to Administration, Firmware Update there is a Check for Update button. "Pressing" this, it thinks for a moment and then tells me there is no update. It does not tell me that there is an available version, and there is no text indicating that I can manually upload one.
The Netgear support page mentions a later version.
- ArodiDFeb 17, 2021NETGEAR Expert
Hi BgTX ,
Thanks for the quick response. If the message indicates there is no FW update available then it would seem like your specific model may be up to date. Can you please help me understand where you found that a newer update was available for your device?
Arodi
