BgTX's avatar
BgTX
Guide
Feb 13, 2021
MR1100 cannot update firmware
Current router fw version: NTG9X50C_12.05.05.14 Latest fw version: 12.06.11.00_00   firmware check using web and app UI, specifies the device is up to date. There is not upload "button" available ...
  • ArodiD's avatar
    ArodiD
    Feb 19, 2021
    Thanks for screenshot. It was very helpful to identify the issue. Your device is MR1100-1A1NAS which is an AT&T variant. The FW in the link you provided is for MR1100-100NAS which is the retail variant. The firmware for your model is upto date as AT&T have not released anything later. I hope this helps clear up the confusion.
