motard
Jan 25, 2025Aspirant
MR1100 cannot update firmware
Hi. I cannot update the firmware on my MR1100 router. It has NTG9X50C_10.12.02.01 firmware now and on the app when I check for updates it comes up with a message saying update error and to try (I...
JBish
Jan 29, 2025Aspirant
Is it an unlocked ATT variant? If so without an ATT sim card you will not get updates
- motardJan 29, 2025Aspirant
It's locked to Telstra (Australia) and the sim is Telstra.
Other info I researched says to just keep trying and it will work but I have been doing that for a week now with no luck. And now the unit is shutting down.
