simplyunique's avatar
simplyunique
MR1100 compatible with gigabit switch
Will the MR1100 be compabile with a gigabit switch so i can wire connect to NAS and PS3 and use the MR1100 wireless to iPADs
  • Yes, I have been running my M1 for the last 8 months with it connected to a gigabit switch. No issues at all. Also the wireless still works fine as I connect my phone to the net at home to it in that configuration. Keep in mind the M1 wifi is very short range. It is designed as a personal hotspot so won't replace a household wifi range
  • JasonN's avatar
    JasonN
    NETGEAR Employee Retired
    Hi simplyunique,
    MicW is correct on their explanation. Please let me know if you need anything else. :]
    - Jason N
