blmeanie
Aug 29, 2021Follower
MR1100 connecting Blink security camera
Bought a NetGear Nighthawk MR1100 hotspot device as a replacement in 2nd home as replacement for crappy support and performance by Xfinity. Got it up and running, connected my laptop to it withou...
michaelkenward
Aug 29, 2021Guru - Experienced User
blmeanie wrote:
Bought a NetGear Nighthawk MR1100 hotspot device ...
As the name suggests, that's a Mobile Router.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
