Wolfy20x5
May 21, 2021Tutor
MR1100 Constant Reboot
I have the MR1100 Nighthawk. It’s started rebooting every 20 minutes or so. It starts doing it after a device connects and as soon as you start using data, it restarts, then is ok for a while and then...
Wolfy20x5
May 22, 2021Tutor
Hi John
Firmware is the latest and no other is available NTG9X50C_12.04.02.00
SKU: MR1100-1EEEUS
Using EE, bought privately and then I use it on EE anyway in the U.K.
I’m not aware of the battery insertion issue. I’ve tried this with and without the battery and it seems to only happen when I have it attached to an external antenna which is a must for my situation.
I’ve also tried this with the original charger, an Apple 1amp charger and a 2amp third party charger as well as same issues.
Odd thing is I never had this issue before with the antenna, I had period of not having the antenna attached and then now attached it and getting these issues. Also, in relation to the below, when I bought this, I wasn’t getting the speed issues either as mentioned below. I’m at the point now if selling this and buying something else.
Any ideas? I also have an issue with it being slower than my iPhone when connected to the same band, significantly slower like 1/3. I’ve used field test mode on my iPhone and compared bands.
SKU: MR1100-1EEEUS
