jsers
Dec 14, 2021Follower
MR1100 Coverage
I recently purchased a MR1100 Hotspot Router. II have good cell coverage and the hotspot is great if it is nearby but the coverage throughout the house is poor. I am confused as to whether I need to add the TS9 Antennae or a couple of Wi-Fi extenders. If so, which ones are recommended?
1 Reply
- JohnPengNETGEAR Expert
The main use case of the device is for travelling. That is why the WiFi coverage can't be compared with home WiFi router. But you still can use the device at home by connecting a WiFi router to its ethernet port. You can use the Wifi rom the router.
TS-9 antenna ports are for LTE signals, but for WiFi.
Thanks
