reasonablestart
Jun 22, 2021Initiate
MR1100 devices show No Internet but hotspot is connected
Had this hotspot for 2.5 years with no issues. Suddenly about a week ago it has started this thing where it will show no changes on its screen (still shows same bars, connected to LTE, connected to X...
JohnPeng
Jun 22, 2021NETGEAR Expert
AT&T just rollled out the new update recently. Could you please do a factory reset and try again. The new update should works better.
Thanks
reasonablestart
Jun 25, 2021Initiate
Hi, I did a factory reset and made sure the firmware was up to date. Today I am having the same problem still. The hotspot restarted itself and disconnected me. It didn't show any messages, other than that it was fully charged and the battery was too hot. I never used to get that message even with it plugged in 24/7. Am I maybe dealing with a bad battery or something?
- JohnPengJun 25, 2021NETGEAR Expert
Can you try using the devive without battery? If the device shows battey is too hot, that might be the reason the connection got disconnected.
Thanks
